1999parkave
- Jun 21, 2023
- 99 park avenue ultra
You've been very generous with your time responding so I am not criticizing you, but the drivers blend actuator cannot be the main problem. The little plastic gears are not gonna be able to turn that door any farther than i can with my fingers (still getting warmish air). Something else is amiss.I can tell you right now your car isnt going to like that and your temp variation is now because of the fact you have a missing actuator
Put a working actuator in, calibrate them (I think I posted how above earlier in the topic) , and then at that point check for codes and see what the behavior is.
I do not have knowledge of the internals on these things. Maybe there is a bad seal on the door. Maybe there's a hole in it. Maybe there is something blocking it from shutting all the way. Maybe outside air is getting in somehow.
It makes no sense to replace the actuator until i can figure out what is the primary issue.
Also, maybe i am ignorant of something, but i do not understand what my car "wouldn't like" about manually adjusting the blend doors to full a/c and then simply controlling the system manually with the on/off button and the fan button. I don't need automatic climate control.
