TheRaven
- May 14, 2013
- Fleetwood, PA
- 2011 Lacross CXL
UPDATE: I have the parts. Spent 4 hours on it last night, and my prognosis so far is that this is going to be very complicated. Despite using the exact same connectors as units i've worked with in the past, pinout is COMPLETELY different than anything i've seen. Also, there are alot of missing wires in my CXL that the navigation system needs. It appears that all but two of these wires are within the scope of the system itself, so essentially, once I find solutions for those two wires, I should be able to make an adapter harness for "plug 'n play" installation.
Right now i'm pouring through GM wiring diagrams to compile all the data I need to make my own diagrams so I can build a harness. I also need to source all the connectors, some of which look like they will be pretty tough to find.
I'll keep everyone posted on progress.
