2011 Lacrosse won't start
msanden
I have had this car for about 3 months now and we are having troubles with it not starting. I have the key/fob unit without the push button ignition. After driving around town for a while (seems like this happens when it gets hot), we get in to start the car and when we turn the key we get one click and nothing else. First time this happened we had a buddy come and jump us, as soon as the cables were on it started right up. Second time it happened I hooked up a battery charger and it fired up as soon as it was connected, third time we let it sit over night and it started fine in the morning. I have had the battery, starter and alternator tested and they all pass. I also hooked up a code reader and it is throwing no codes. Called the dealer where I bought it and they said that before they sold it to us they put in a new battery, ignition coil wire, and starter because an ignition coil was triggering the service engine soon light. We bought this car used at a Ford Dealership and it is past the 30 day warranty so that dealership is no help to us.
I think it might be the key/fob batteries so that is next on my list of things to do.
Any help would be greatly appreciated.
The key fob batteries have nothing to do with your problem. Assuming somebody has also checked the battery cable connections at the ground and the starter, I would suspect a bad starter solenoid since the problem occurs when the vehicle is hot.
Well I finally caved and took the car in. Turns out it was a 'maxifuse' for the starter? I had looked at all the fuses in the fuse box, and they all looked good. I had also tried a different starter relay thinking that might be the problem as well and that didn't work either. The dealership could not really show me where this 'maxifuse' was but it was a 6 dollar part so it was not the 140 dollar fuse on top of the battery. Since it was in intermittent problem I am thinking the fuse was just 'weak' and not completely blown?
Thanks for the help.
could you tell me where the fuse is and what size is the fuse
REAL GOOD POINT !!!!
