Transmission fluid change and oil change
luke_dubs
2013 Buick Regal GS
I've only had my Regal for, uh, 11 days now, and I want to change the transmission fluid (as I don't think it has ever been done on my car). I've done some research on this forum and google for what fluid to use, but I'm having trouble finding how to change the transmission filter itself. I also would like to know how much transmission fluid I'm supposed to use.
In terms of oil, I know which one to get. But which filter should I choose, and how much oil should I put in?
Thanks in advance.
Concerning engine oil your owners manual, page 12-2, shows 6.3 quarts but the manual is known to be wrong sometimes. Buy 6 quarts, put in 5 and after starting the engine, check the oil level.
I would buy a NAPA Gold or Wix filter or the original AC-Delco.
https://my.buick.com/content/dam/gm.../2013/buick/regal/2013_buick_regal_owners.pdf
How many miles on the car that you feel you have to change the transmission fluid. Does it smell burnt?
Page 12-3 shows the capacity but states it does not need to be changed.
There also does not appear to be changeable filter other than in transmission tear down.
The link below is for the Chilton's online repair manual and the password is nvlive001. It tells you how to drain and fill the transmission but there are 2 different transmissions listed for your car so you will have to find out which one you have.
Gale - Product Login
Are you sure that's the password? Tried it 3 times and it didn't work.
According to GM's "recommendations", they say that the transmission fluid should be changed every 40,000 miles. I'm at 63,500 miles and I do not know if the fluid was replaced at all. I just want to do it now so I don't really have to worry about it for the near future.
Leave it to the Germans to make a transmission fluid filter change difficult.
Sorry the password is nclive001. Try accessing it in the link below. Scroll to the bottom of the page and there's a another link, don't use the one at the top of the page.
Free Chilton Online Repair Manual
My '17 doesn't even have a dipstick to check the T-fluid and I'm not comfortable w that. How's one supposed to check and gauge the degradation of the fluid between services?
Probably the only way would be to empty a small bit of transmission fluid and inspect that. I know the '16 2.0T Regal (not the GS) has a transmission fluid dipstick. Too bad there were too many idiots in the past putting the wrong fluid in their transmission and then blamed the manufacturer. That's why there really aren't transmission dipsticks anymore. 'Tis a shame.
  • Like
Reactions: Vic
Have you looked while standing in front of the car to the left and slightly forward of the battery compartment for a roundish cap which states only put in transmission fluid?
If you turn it counterclockwise and pull up you will find a rather long dipstick with a measurement area on the end.
This is the third time I know that someone has had to be told this. Maybe there should be a sticky about dipsticks. 😂
Found it, thanks.
Found it, thanks.
It is a lil tricky to find and I can see how any of us who are used to traditional locations could miss it. The question does come up quite a bit so don’t think you’re alone.
My manual says change at 40,000 miles under "severe service" only.
Make sure you get the correct ATF. There are 2 different ones for your car (depending on the transmission)
I'd get AMSOIL OE Fuel Efficient ATF because it covers both the AW-1 and Dexron-IV ATF.
. . . Leave it to the Germans to make a transmission fluid filter change difficult.
If the 23rd Century Germans build the Starship Enterprise, Scotty will have to remove both engine nacelles every 20,000 light years to change the dilithium crystals.
I bought the transmission fluid recommended earlier in this thread. But, does anyone happen to know how big that torx nut is in the picture? That is where I put new fluid in the transmission (according to the linked repair manual). I might already have the bit; but I still want to know, just in case I do not have the bit.
Looking for the torx size. Here is the correct procedure.
