MillenialCXS
- Aug 10, 2019
- 2010 Buick LaCrosse CXS
I am so glad that you found something that works. Hopefully it works anyway lol. Does it seem to ride correctly? How did you arrive at those part numbers? I called AC Delco and the rep here tried extremely hard to find something that it would cross over to. He even let me go so that he could call some regional rep or guy at AC Delco in MI and was told the same thing, that there was nothing to cross over to.
Just to confirm, you have the touring package, 19" factory wheels, H-arm rear end and the electronic shocks? Thanks again for the detailed write up also.
i have all of the same specs as your car. H-arm, 19” wheels with Touring package and the driver rear was the electronic shock absorber that went bad for me. I got tired of the dealers and AcDelco giving me the run around so i took matters into my own hands. If you take off the wheel, you will be able to see the shock absorber and on the shock absorber is a part number that is different than the assembly number you were given from the dealer. Since the shock absorber is the only thing that is bad, you can take apart the shock absorber assembly to replace just the shock absorber itself. Follow the replacement just for the shock absorber since this is the piece that gets plugged into the car’s electronics. This is process and thought pattern used to replace mine. I dont get the service suspension light anymore and it drives like new. I bought the other side off ebay just in case the right rear goes bad just so i dont have to go through finding the replacement again.
