2007LucerneCXL
- Jun 19, 2015
- Illinois
- 2007 Lucerne CXL. and 1995 Lesabre currently, past 1973 Riviera, 1968 Riviera
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Yes, number 3 and its attached bits. It doesn't appear to route that way on my engine, so that may explain it. I'll have a better look at it in bit. Thanks for the diagram, by the way!Is this the line you are referring to in the drawing. If so you may see how it is routed and if anything is not installed correctly.
I suspect it's an input to for the transaxle to sense engine load, e.g., lower vacuum (higher manifold pressure) equates to higher engine output and thus makes it more likely to kick down a gear in order to realize higher power output.Do you have any idea what the item is that the line goes to?
I can't figure out what the vacuum actuator would be.
One end goes to the throttle body and the other end to the vacuum modulator. It controls the quality of shifts based on engine load which is measured by vacuum.Do you have any idea what the item is that the line goes to?
That's apparently correct because when I reconnected it it shifted into gear like I was at idle instead of flooring it during my test drive.One end goes to the throttle body and the other end to the vacuum modulator. It controls the quality of shifts based on engine load which is measured by vacuum.
With these old cars a couple of feet of vacuum tubing and some various straight and tee connectors are a must.That's apparently correct because when I reconnected it it shifted into gear like I was at idle instead of flooring it during my test drive.
Incidentally, I managed to fix it by rotating the actuator a few degrees clockwise, which put the nipple in line with the vacuum line perfectly and I can probably expect it to stay put. It also improved the idle and reduced the idle speed noise dramatically to where it actually sounded and acted like it's supposed to.
Thanks to all who contributed to the discussion!
I need the number 15 piece![]()
1997 Buick Lesabre CUSTOM 4DR VAPOR CANISTER & RELATED PARTS-V6 3.8K
I'm posting this drawing just for reference.
Need the number 2 pieceIs this the line you are referring to in the drawing. If so you may see how it is routed and if anything is not installed correctly.
