Frankythemainman
- Aug 5, 2021
- 1995 Riviera S/C
I have a 95 Buick Riviera S/C the other day I was driving and the low voltage light came on and then went off and a second later the check engine light came on and the speedometer jumped around then hit zero and I only have 2nd and 3rd gear now, the check engine light is still on and nothing changed after I have replaced the speed sensor and looked for any broken wires in the wire harness leading to it, I also checked all the fuses and replaced the negative Terminal on the battery the transmission fluid and oil was changed a week ago any help would be appreciated
