Paula sounds great!Loose wheel lug nuts, loose suspension parts, loose brake parts, loose stuff rolling around in the spare tire well?
I used to get a thud on the front right of my Chevy Volt which was solved temporarily when Paula, the attractive Chevy service manager torqued my nuts (the big one that holds the front end assembly to the axle). a few years later the thud returned requiring a bearing replacement, a new washer, and another nut torquing. I love having Paula torque my nuts. I don’t know if the TourX rear axle has any nuts to torque.
What about the heat shields over the mufflers? Those things make all kinds of noise when they’re loose.Paula sounds great!
No ,dealer has had it up on alignment rack,new shocks installed. Definitely not the obvious.
Growing tired of this Buick that I haven't been able to enjoy because of these issues.
I have this grinding popping sound as well. I think your video link is the best guess. I also had my rear stabilizer bar or whatever it is called replaced under warranty because the rubber was squeaking. Dealer said it failed prematurely.I also have this problem and came across this. Make sure you bring this up to the dealer when you take it in. It looks like this is a very common issue with the gen 9 malibu and they have the same part.
Is this possibly a Technical Service Bulletin (TSB) item?Just left dealer. They heard noise loud and clear and traced it to a strut mount. Ordered part for install next week. Will advise !
I got this fixed at the dealer last week. I wanted to give it some time to make sure, but replacing the rear knuckles was absolutely the fix to this for me.I have this grinding popping sound as well. I think your video link is the best guess. I also had my rear stabilizer bar or whatever it is called replaced under warranty because the rubber was squeaking. Dealer said it failed prematurely.
I’m having the same sound like a strong thud from rear driver side mostly. Do you have a video of yours?At start and stop, also backing up getting a thud/ knocking sound from rear. Also from start to 10 mph, deceleration 10mph-0. Dealer can't figure out.
Did you resolve issue? I’m having the same issue.It's not a rattle at all but a solid thud. Almost like the suspension is binding up and then releasing. Thought it was the upper control link or something but dealer is lost. Had them switch tech's due to receiving the car back with the same sound even after replacing rear shocks under warranty
Did you resolve the issue? I’m having the same issue. Mechanic is unable locate. I’m confused either to replace strut mount or rear knuckles.Just left dealer. They heard noise loud and clear and traced it to a strut mount. Ordered part for install next week. Will advise !
I would be curious to know how long replacing the knuckles fixed it. I have a 2018 with the noise. I had the rear shocks, upper and lower control arms, and the wheel bearings replaced. It made the car drive better but the noise was the same. The shop then replaced the rear knuckles and it stopped the noise on my car too. But it was only for about 5 weeks, then it came back just like it was.I got this fixed at the dealer last week. I wanted to give it some time to make sure, but replacing the rear knuckles was absolutely the fix to this for me.
