JGBuick
Sustaining Member
- Jun 8, 2020
- 2001 LeSabre Touring Edition
The scanner I purchased does have the ability to test the ABS system.Did you have to bleed your ABS after the repair?
This scanner allows ABS auto bleed through the OBD2
https://www.amazon.com/gp/product/B07CSMJJK9/ref=ox_sc_act_title_1?smid=A2YWURTSRUAKKQ&psc=1
Does the Buick LeSabre have the auto bleed through the OBD2?
No I didn't. Since I didn't open any of the hydraulic lines or mess with anything like that, I didn't need to bleed anything. (I just worked on the solder joints).
I purchased that scanner on a 'whim"... I'm sure there are much better scanners out there. (The Foxwell scanner you linked looks decent also.)
The scanner I purchased has a learning curve and the interface (report) mainly links to my phone app. It gets the job done and the company apparently knows what it knows.
Having notated that - I'm sure they hold-back features on the lower priced models. I wasn't going to spend $400-1,000 on a scanner and so forth.
Hope this helps.
