A/C-BLOWER MODULE The Blower Module corresponds with the following part Numbers: 25500218 25508543 25503141* 15-71527 *requires slight modification to the mounting plate. INSTALLATIONin PDF format
www.casperselectronics.com
Now, I dont know for a fact this is going to work, but it works on regals, is the same shape, and I would think the controller in a regal is probably the same as the riviera. The C68 climate option is a rare thing to find in 1980s vehicles, let alone survivors, let alone just how many brand new ones there were. So this appears to be the only reproduction i can find. the module is redesigned so the prongs arent on top of it(water damage and corrosion common)
1985 Riviera Electronic Climate Control Issue place I found the info I posted
before replacing it: Do you know your resistor is dead? This is a lot of money for this part, so you would want to be sure. Most resistors when they die will work on full speed but nothing else
