OPL Monitor
danzig997
47°40′10″N 122°7′26″W
TourX Essence with Opel Insignia DNA.
OPL Monitor - This application is dedicated to users of Opel and Vauxhall cars. I wonder if someone tried to use it with the US version of Insignia B? Free app.
Opel Insignia B From 2018
2.0 TB20NHT, F20SHT
2.0 TB20NHT, F20SHT
This is an app I stumbled across some months ago.
Provided you have the right kind of OBDII adapter, the app and all its advertised functions work just fine on our cars. The developer is very responsive as well.
Damn you.......spending more money
The app is free and should work with the US versions of Insignia B:
" Yes, it’s the same car, from the same plant if VIN starts from W04. The app should recognize VIN after decoding. If not then let me know. "
The app is free, but there are certain functions which require in-app payment to unlock. For example, if you've upgraded your cluster to the 8-inch screen, you can change themes or activate menus through the app. I can't speak as to whether that's possible for the 4" screen, but I would assume it would be. You can also activate language options/change themes within HMI, along with a few other fun tools.
Can't recommend it highly enough.
Do you know if you can change themes within HMI on 2018+ vehicles i.e. white needles? Looking to change from Buick to Opel.
Can't say for sure on that point - mine's a red needle 2018 - but I would think you would be able to do that on a white needle as well. Don't quote me though...
This is the same kind of stuff White Automotive and Media Services did for me with my GS cluster. If the same types of things can be unlocked, this is a neat tool, but there are limitations to customization with how our cluster and HMI are setup (i.e. some themes or brand changes are not possible).
That may be true, but there aren't many themes which aren't available, at least so far as the cluster is concerned. (Off the top of my head, you can get Opel/OPC/Unlimited, Vauxhall/VXR, Buick stock/GS, Chevrolet, and Cadillac using this app.)
Does anyone know if you can make it remove the added gauges? For example if I needed to go in for warranty work and the dealers see the custom/different gauges 😁
I just tried it out.
Doesn't do much without a $7 yearly subscription.
Then it is a fairly good diagnostic tool. Checks all monitors and modules.
Cleared codes, etc.
But, for any gauge revisions, it will be $59 for access.
I think not......
I tried the app and was able to activate oil temp pocket gauge and speed sign recognition on dash and HUD
Speed sign recognition would be handy. Does anyone know if that function is baked in but not turned on for all models. In other words is the underpinning hardware fitted by default?
I'm not sure but I think it is connected to the camers in rear view mirror if rsv has one maybe it will work
So if I understand correctly, this seems like a favorable approach to unlock the extra menus vs White Auto 1) cheaper even with the $59 add on fee and 2) no dash disassembly 3) most importantly no need to be without a cluster while they update.
