TimeTravel
- Aug 13, 2022
- 2007 Buick Rendezvous
I have a 2007 Buick rendezvous.
It cranks but doesn't start.
Usually happens when it's been sitting for 12 hours or so like before and after work.
A mechanic replaced the fuel pump.
A mechanic also replaced the theft deterrent control unit and programmed it.
It will try to start when I add starting fluid but doesn't stay running.
I've tried starting it in neutral.
I tried removing the vent solenoid fuse.
This is an intermittent problem. Sometimes it will start up after 30 minutes or so and sometimes it won't.
I also have a cheap code reader and no code showed up. Although I did get the expected code after pulling the vent solenoid fuse of po449.
Any help would be greatly appreciated.
