BuickGirlFromMars
SUPER STAR!
- Oct 8, 2018
- 1999 Buick Park Avenue Ultra (Supercharged) , 1977 Buick Electra Limited (350 SBB)
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
is the flange that bolt to exhaust manifold and right behind this flange is a steel & stainless steel flex joint(as can be seen in my previous post) the inner steel pipe breaks over time and cause exhaust leaksTo remove the front and rear flex-plate dust covers, will I need to remove those cooler lines to the transmission, or is it just a few bolts? The GM instructions didn't specify how to remove the front and rear.Yes.
Also since we are on the topic of vibration when accelerating, can you turn your attention to your torque axis mount when on the lift. Its the one near the oil pan (there is a large bracket off the oil pan for it)
it should look like this (near the crankshaft)
Also take a look at the trans mount near your radiator(also mounted low and near that circle in your pic) and the trans mount near your driver side wheel. Send pics if you can. There is also one on the subframe (the thing holding the engine and transmission) near the steering rack. If you send pics of them I can tell you any thoughts about them. Its a good thing to check while its in the air.
Thanks, understood, I was talking about a different bolt now for the flex plate front and rear dust covers. Checking the flex joint that you've highlighted here is still on the list to diagnose as well. Thanks!Never said anything about bolt being missing I said because you had the downpipe welded to cat replacing the downpipe with the flex joint is no longer a bolt on application below is a pic from my engine swap 4.5 years ago red squareView attachment 44679 is the flange that bolt to exhaust manifold and right behind this flange is a steel & stainless steel flex joint(as can be seen in my previous post) the inner steel pipe breaks over time and cause exhaust leaks
if you can get it up to get under there best way to do it is while its still cold that pipe get very hot very quick alone with the cat so while car is cold start it and reach up in there and feel around the flex joint with your hand see if you feel exhaust coming out through the stainless steel braiding I would bet that inside pipe has broken. Or if you have access to a smoke machine run it up tailpipe that would tell you real quick to and if not leaking there it would show you where it is as for the flex plate cover two 10mm bolts remove itThanks, understood, I was talking about a different bolt now for the flex plate front and rear dust covers. Checking the flex joint that you've highlighted here is still on the list to diagnose as well. Thanks!
There is a single push pin that holds the lines to the same placeTo remove the front and rear flex-plate dust covers, will I need to remove those cooler lines to the transmission, or is it just a few bolts? The GM instructions didn't specify how to remove the front and rear.View attachment 44680
hmm. those all appear normal.does this help?
I'll take a look at that once I jack it back up this week. Thanks for all your responses for this!hmm. those all appear normal.
There is a heat shield that covers the steering rack between the exhaust and the rack, is that tight
send pics of your exhaust hangersUpdate:
Had a mechanic smoke test the exhaust system and saw nothing come out, but he definitely heard the clicking while driving so I'm not crazy. He used his stethoscope and said he could hear a leak coming from this phalange but could not get smoke to come out of it. He thinks it's such a small leak but gets exacerbated when driving the car (I only hear it when the car is accelerating and moving 10mph+ approx).
So, he recommended leave as is until the leak gets worse and we can detect via smoke, but that the phalange is his best bet.
What do you guys think I should do, and if I wanted to replace that phalange / pipe would I just use the part# from the image BGFM shared #52270 and have a shop bolt/weld on for me? Thanks!View attachment 46852
then its probably the flange, and you are right on the exhaust hangars lol I forgot this was the same thread I asked that.Hey BGFM, I think I posted pics of the exhaust hangers in a previous post here and you mentioned all looked ok. The mechanic heard the leak coming from that flange while the car was in the air and he was under, but he couldn't get smoke to come out of it.
The clicking is directly proportional in volume and speed with my throttle, so it really sounds like an exhaust leak to me. The fastest I accelerate the faster it clicks, and disappears the instant I let off the throttle even if I'm coasting. I'm not sure what the cradle/engine assembly is nor about the transmission mount or PS lines.
