FSUDAL
- Jan 8, 2024
- 2010 Buick Lacrosse CXL AWD 3.0L
My parents gave me their old 2010 Buick Lacrosse CXL AWD. The a/c blows only a little cold (60 degrees at vent in 75-85 degree weather). I added pure r134a and the temperature dropped to 30 degrees. Thought success! Later that day it was back to 60 degrees at vent. Gave up and took it to repair shop (national chain). The evacuated the system and recharged, checked for leaks, checked pressure, and changed an old Schrader valve on the low side that leaked briefly when disconnecting manifold gauge. Right after it was recharged, once again, blowing nice and cold. Thought success! A day later back to blowing 60 degrees at vent. Drat. Took back to shop first thing in morning. They rechecked pressure, leaks... and said everything was working properly. Of course, it was only about 65 degrees out at the time and blowing close to 40 degrees at vent. Explained that when warmer will not cool that low. Sure enough when it warmed up to 80 degrees I was back to only getting 60 degrees at vent. No real changes when idling in park, driving around town, or on the highway. Shop said I could bring it back when warmer to have them look again. It doesn't seem to be an intermittent problem.
The only clue that I have is it blows nice and cold right after a recharge but then back to 60 degrees at vent in 75-85 degree weather. What do you think could be causing this?
