Map Sensor Location
ayookam
Regal GS
Does any know where the map sensor is located on a 2014 buick regal GS AWD?? it would help tremendously
Under intake/engine cover attached to throttle body.
I have a 2017 Regal Sport Touring 2.0L Turbo...I cannot find the MAP sensor. I have removed the main engine cover. Where do I look from here? Not sure what the throttle body looks like on this particular engine if we're using the throttle body as the guide. Feeling a bit dense here, sorry. Thanks.
Thanks. I found it. Used a mirror on the back of the intake manifold and there it was adjacent to the large plastic air intake. I still seem to have the intermittent P1101 even after changing the MAF, the MAP and the PVC. Air filter is new, air filter box is fine, not clogged. Any other ideas of what I can look for that may be causing the code?
Did you use OEM parts? These cars are very picky with MAF and MAP sensors.
Also, make sure the connectors are clean and fully seated.
Yes. I've learned my lesson there. The MAF was AC Delco and the MAP was GM.
not being funny but did you clear the code with a scan tool ? after installing the new MAP sensor
I did not clear the codes. Will do that. Thanks for the suggestion.
All, I'm still dealing with an unrelenting P1101 code. Since the code appeared several months ago, I've replaced:
The MAF (AC Delco)
The MAP on the intake manifold (GM)
The MAP on the intercooler tube (GM)
The PCV valves and hoses (GM)
The intake air tube (GM)
Codes have been cleared and code returns almost instantly.
Has anyone else experienced a P1101 that just refused to be fixed? Please let me know if there is anywhere else I should be looking.
The MAF (AC Delco)
Same issue with a 2016 regal 2.0 Turbo
I just want to say good sir....for I have a 2015 gs awd....it's my understanding the maf sensor is a Hitachi one. I could be wrong
Same here, same issue, same model. My symptoms are that when lightly accelerating after a stop, the engine or the trans, not sure, starts noticeably shaking. Shaking will stop when releasing pedal. Shaking is much less common when pressing the pedal heavier
I’m having the same issue with my 2017 turbo
