tomwssamarine
- Nov 20, 2023
- Lesabre
Part 5Part 4
So I just disconnected the left side to the switch and disconnected the right side also and then connected the left side of the switch to the right side, this is not needed to be done, but I just wanted to see if the problem was in the wiring, which it wasn't
Further I did completely disconnect all wires so I could look closer at the removable air, horn, radio control part, and that step is not needed, I was just curious
Then just put the air, horn, radio control part back in place
Then before going forward, press the horn and it should work
If not check the position of the switch and the cotton stuffing, with the cotton stuffing securely holding the switch in place, as the switch has to be pretty close to the exact location to work
I know I know, how weird the switch is and what the heck went wrong to begin with
I'm not sure why this works but I needed to get the state inspection today and the horn needed to work
In my case only the right side of the steering wheel horn works, with both horns under the hood working when pressed
Its possible the left side of the steering wheel horn could work if I hooked it up, but I will save that for someday when I have free time
Further this week I saw an ad in eBay showing the air, horn and radio control part and that gave me enough courage to try to fix the issue myself
Lastly total time to fix stuck horn issue is less than 10 minutes the second time, but the first time around take ur time and there is little chance u will break anything
Further if u know which side appears to be failing, u only need to disconnect that side from the switch
The device from Walmart the clamps down on the air, horn and radio control part can help determine which side is failing
I can live with just one side of the steering wheel horn working and so I passed the state inspection today
Good luck and I am clueless as to why or how someone said they removed foam as the solution as I did not see any foam
Good luck
