Crazyc
- Nov 12, 2024
- Park avenue
This discussion covers Buick lesabre / park avenue / Lucerne / bonneville / Cadillac DTS
Rear subframe rotting rusting or bad bushings.
The rear cradle I’m using for my 2002 buick park Ave is out of a 2011 Lucerne. The park Ave rear cradle clamshell design has rusted and failed due to it holding water, an oversight GM apparently realized 5 years into this platform and made necessary adjustments.
The newer (06+) tubular design in Lucerne allows for water mitigation. Noted differences are braking system, calipers and E-brakes backing plates and the leveling system has been moved from the rear sub frame to the unibody. I’m planning on cutting that bracket off and welding to the newer frame. I may have to bend it or modify it to sit properly but bending it until the car sits at the proper height shouldn’t be a big issue. I haven’t verified if the unibody has the mounting location for newer style on the older car. I’m assuming not.
At minimum, I found that the bushings in the newer style subframe are the same (superseded) bushings. Although also no longer available, plenty of these newer 2006-2011 cars in the junk yards to pull subframes or bushing out of that aren’t annihilated. You can remove cradle and pull these bushing out, and assuming your cradle comes out in one piece, you can reinstall these bushings into your cradle.
See pics attached to see the older and newer frame style.
