Passenger side air temp problem...always warmer 2007 Lucerne
TomP
Sustaining Member
MD
Buick Lucerne '08 CXS, '10 Super, and '07 CXL
I have the glove box out, and can watch the operation of all three blend actuators on the passenger side while I change the setpoint. They all seem to work! None of them click, or fail to move. The air temperature on passenger outlets are 10+ degrees warmer than the drivers. Any help appreciated.
This is a great car with only 110K, but it did need the top side of the 3800 done for losing coolant. Runs great!
The actuator is the most common problem on the temperature difference. The two other items to check on the AC charge and on heat is the core doesn't have any air or blockage. The other item would be doing a calibration on the actuators, couple of internet posts on the method.
The AC charge? Wouldn't both passenger and driver be the same temp if that is the case? The actuator you highlighted does rotate and seemingly change to its opposite stop when temperature is switched from cooling to heat.
Low freon levels can effect left and right side on AC in some cases. The highlighted is the most common actuator for L&R temp differences.
When I bought my 2008 Lucerne 5 years ago, it was blowing warm air on the passenger side. Got the system recharged and it has been fine ever since.
I've got the opposite problem in my '08 Lucerne. Now that winter's approaching I'm cursing the fact I fixed the A/C because it's blowing cold air at feet, face and/or windshield on the passenger's side even when the temp's set at full-hot for both sides.
After getting the glove box out it's obvious the actuator is OK - it cranks the arm that appears to be moving the actuator just fine. But no matter; I'm only getting icy-cold air on the passenger side.
Next chance I get to spend time in the passenger's footwell I'll look for a way to open the heater box up; maybe the door is slipping on its shaft.
Does anyone know if the heater box opens up without taking the dash apart? If it doesn't I'm considering cutting into it with a Dremel.
Has anyone been in this spot already?
Have not had the problem, but the diagram may help. A dealer or a Tech2/similar scanner may be something to consider to identifying which actuator may be the problem. As with the AC low coolant in the heater core should be checked again just a FYI.
