2016 Buick LaCrosse - Jack Stand Spots for Oil Change
gfr92y
LeCrosse
Vehicle: 2016 Buick LaCrosse 3.6L V6 Sport Touring FWD
Last time I changed the oil, I used low-profile ramps and did not have room to move.
I am planning to lift the vehicle at the pinch weld using a low-profile floor jack and custom lifting pad, but do not know where to place the jack stands.
The service manual says to only place jack stands under strong and stable vehicle structures, but it does not identify what or where they are.
I would greatly appreciate any recommended jack stand spots.
Thanks!
gfr92y
You are looking for the "pinch welds". Follow that diagram and look for spots along that seam that look pinched. On my 2010 there are also two small circles imprinted above the right spot. I'm doing an oil change also and have kind questions along these lines. Those points will definitely work with jack stands, but i'd like to use my low profile floor jack to raise the entire front end up and then put the jack stands in place. I am concerned with doing this safely for me and the car.
Riddled,
I am planning to lift the vehicle at the pinch welds using a low-profile floor jack with a custom lifting pad and I know where they are located.
What I do not know is... Where is a "strong and stable vehicle structure" to place the jack stands.
The shop manual refers to a "strong and stable vehicle structure" but does not identify where they are located.
