Driver Personalization
BarMixer
Delaware
2005 Lacrosse 2013 Verano "T"
I am reading the owner's manual for my 2010 Lacrosse CXL with Nav system. The manual talks about personalization by driver, but I can't find it. What am I missing?
See section 4-38 of the owners manual. This is an excerpt of the section
Vehicle
Personalization
The audio system controls are used
to access the personalization
menus for customizing vehicle
features.
CONFIG (Configuration): Press to
access the Configuration
Settings Menu.
MENU / SELECT Knob: Press the
center of this knob to enter the
menus and select menu items.
Turn the knob to scroll through the
menus.
0 BACK: Press to exit or move
backwards in a menu.
Entering the Personalization
Menus
1. Press CONFIG to access the
Configuration Settings menu.
2. Turn the MENU / SELECT knob
to highlight Vehicle Settings.
3. Press the center of the
MENU / SELECT knob to select
the Vehicle Settings menu.
The following list of menu items will
be available:
. Climate and Air Quality
. Comfort and Convenience
. Collision/Detection Systems
. Language
. Lighting
. Power Door Locks
. Remote Lock/Unlock/Start
. Return to Factory Settings
Turn the MENU / SELECT knob to
highlight the menu. Press the knob
to select it. Each of the menus is
detailed in the following information.
Does any owner have experience with personalization, and what can be personalized? I have a CXL with Nav.
I have a CXS with nav and also missing the "Personalization by Driver" entry. Not only that but the "Remote Start Cooled Seats" or "Heated Seats" don't seem to work. Can't get them to turn on with remote start no matter what.
Called the GM customer help line but they had no idea. Looking for answers...
I can't get the door locks to function as they should. There is one menu choice that won't work as the manual says it should. I should be able to set the drivers door up to lock five seconds after exiting the vehicle but it will either lock immediately or never.
My guess is the programming in the module that controls this needs to be reflashed. I'm sure the dealer could fix the issue. It slipped my mind when I had mine in for the brake issue.
