dondee
- Aug 14, 2018
- 2005 LeSabre
The rear wheels have negative camber and the tires show accelerated wear on the inside 1/4 of the tread.
Had alignment check and the mechanic said the bushings on both suspension control arms need to be replaced as well as some other parts.
The springs(moog) and shocks(monroe) were replaced about 3 years ago, but I only put about 3-4000 miles a year on the car so don't see how they could need to be replaced.
The leveling system seems to be working fine. It tests(runs) after starting the engine, I can load down the trunk and the system levels the rear.
Two questions:
What is the riding height measuring from ground to opening of fender well through the center of the wheel? (or a better way measure is acceptable)
Where can I find replacement bushings for the control arms?
Help is appreciated.
Two questions:
