07 lucerne 3.8L water pump
A full system flush is probably a good choice if it's never been done or previous history on maintenance is unknown. Here's some diagrams on the system which may help. On the heater core it's #44 and there are older post on R&R but from what I remember on the post the entire dashboard needs to be disassembled so it's something that should be confirmed.
Contrary to what Mad Coachman said, pullys HAVE gone bad on me, twice. Caused a belt to freeze, and with no belt turning the water pump, it was not working, and that was causing the overheating.
So you're the exception. I guess I should have said they "rarely go bad".😎
The hose that is near the engine is the input to the heater core, not sure if it's required to go the same direction. If not done yet this may be a good time to replace the plastic elbows with metal ones and thermostat if needed.
The other item if the heater core is good and no air in the coolant system is the actuator(s) on the interior may be bad or is hung up for the lack of heat on a side.
I was able to run water through both ports of the heater core. Everything seems to working ok at the moment. Will check back in if things not looking well. Thanks for the dashboard picture as well. Major help!!!
Hopefully all will work out with no problems, good luck on getting it finished.
When I run water the hose through the heater core what do I look for exactly? Never done anything like this before
Once the coolant is out it should be clear, but on any vehicle there could be some sediment that may also come out. It's kind of how much or how little has been done maintenance wise over It's history.
Oh OK thank you! Also where would I find a new pulley? All the auto parts store here don't have them in their system. Or is the old pulley reusable?
I got mine from a junk yard look brand new
Your pulley is probably just loose or your water pump is REALLY bad.
There's a good reason that auto parts stores don't stock the pulley. They don't go "bad".
Sorry but they do go bad they get hot plus the pulley is plastic
I think you are referring to the belt tensioner pulley.
What engine do you have? I'm referring to the 3.8
Oh well does it matter
totally different engine. Totally different water pump. The engine in post #6 and #41 is the 3.8 liter V6.....Yes it does matter if you're referring to a V8 as opposed to a V6 which was the topic of discussion here.
What engine do you have? V6 or V8?
V8 Northstar paul8539
