ayalayvonne
- Jan 15, 2023
SOLVED!!!!! Both of my rear doors stuck shut, wouldn't open from outside or inside, the locks seemed to be working properly. After scouring the web I found a post explaining a design flaw was responsible. If the doors were unlocked while someone was pulling on the door handle the mechanism would get stuck. I was able to get the inner door panel removed without breaking anything, only the backseat bottom needs to be removed. It takes some finesse to get the bottom clips undone but IT IS POSSIBLE. Once I had the door panel removed I was disappointed that pulling on the lever from inside wasn't working to disengage the door. Finally I recalled the post that explained why so many people were experiencing this issue with the cars. I reversed the action that caused the issue to begin with, pulling the lever thats connected to the door while holding it I unlocked the door and it finally disengaged. I will post of video when i get around to the other backdoor
