century61
- Aug 18, 2008
- Indiana
- 2008 Buick Lucerne 3.8 liter
You do not have a short. A short would blow the fuse.
Most likely you have excessive voltage drop across the fuse relay terminal connection.
Once the original relay overheated (for whatever reason) the female terminal the relay plugs into 'enlarged' and now has poor contact. Your dropping voltage at this connection and the current is overheating the plastic.
If you cannot take the fuse relay center apart to REPLACE the female terminals you have two options:
1. Replace the fuse relay center with NEW.
2. Remote mount a new fuel pump relay OUTSIDE the center.
Obviously this second option is way outside warranty and dealer repair options. You'd need a electrical tech who really knows his stuff.
So, In essence you are saying its not actually a higher voltage that is burning up the relay but because of increased resistance at one or both of the posts coming from the supply side of the relay (were the burn is) it produces heat and actually overheats/burns the relay?
I take it you have encountered this before? Therefore the fix is probably a new fuse box under the seat.
How am I doing?
