mr. clean
- May 14, 2019
- 2010 Lucerne Super
Forgive me if I am mis-reading these last few but have you guys not read through this thread re: the TSB (“Technical Services Bulletin”) concerning this Fuse Box/Fuel Pump/Shorting Out/Rear Seat issue? They might fix it for free!Yeah dealing with the same problem let me know if you figure it out what that was.Thanks.
In other news...I need advice: my 2010 Lucerne Super‘s driver’s power window hasn’t worked in months. The other 3 work fine. The switch is sending power to the window motor and the motor works fine. The window pulls up and down easily enough by hand so am guessing the regulator is fine. Tried a different motor and a different switch with the same issue. Tried grounding the motor to the negative post on the battery and other spots with no joy; any ideas?
