JGBuick
Sustaining Member
- Jun 8, 2020
- 2001 LeSabre Touring Edition
Hi All,
Thanks for reading this... I'll get to it.
2001 LeSabre with almost 60k. Beginning to be hotter than Hades here in AZ. Car has never seen any type of A/C work with this exception -
Last week I added a few ounces of 134a into the system to see if I could fix a "Driver's side vents blowing warm" condition. (Checked actuators and they work fine.)
That actually worked. I now have cold air on BOTH sides of the dash. Go figure. I'm told after twenty years... things have away of leaking out.
Now... perhaps its' just because.... and I've been running the A/C quite a bit... Today, I noticed a few small sticky-oily green florescent drops on the garage floor.
I always check that area and it's been spotless since I completed my intake/valve cover/gasket/elbow/plenum/wires job months ago. Anyway...
I wipe the few drops from the floor.. Not tranny fluid, not motor oil.... Not power steering... Gotta be compressor oil. (Did the factory come with green/yellow dye in it?)
So.... I'm concerned. I plan on getting under the compressor to look closer this weekend. Doing some research and apparently O=ring seals go bad...
Questions - Is this a coincidence to me adding refrigerant? (about a half shot-glass of fluid loss on floor) What am I looking at here? Just seals and parts or a whole new compressor? IS there a blockage or something? Have any of you repaired your own A/C before? Is the LeSabre difficult to work on with A/C?
I know these questions are speculation... but??? Looking for some answers about how to approach this issue.
I appreciate anything you can tell me. Thank you!
