abizzle
- Jun 19, 2021
- Denham Springs, LA
- 2018 Regal Sportback Essence
I am in the middle of changing my compressor, which also requires several other parts to be replaced along with flushing the lines and recharging. Before my compressor died, the AC was annoyingly loud, so I'm hoping all of this work will somehow address that issue as well. I've had to disconnect and disturb the original positioning of all AC lines during this process and today I'll be disassembling most of the dashboard in order to reach the evaporator and expansion valve. It's about as close as you can get to doing a full AC system replacement without replacing the lines. I will report back on the results.
On a related note... you do NOT want to undertake this project unless it's absolutely necessary. A compressor failure will most likely send metal shavings throughout the entire system and not properly cleaning the system is just asking for future problems. Easily the worst car maintenance project I've ever done.
