Blend Door Actuators - 2000 LeSabre
Well first I would check the heater core. It’s easy. Get the car warm, then grab the large hose going to the heater core. It’s under the hood near the alternator. It should be hot, almost so you can’t touch it. Then grab the return hose, it’s the smaller one below the supply hose. It should feel the same temp as the supply hose. If it does not then you have a restricted heater core. Check that first. Once you do that check back!
The heater core was flushed last year when the heat had gone out. Then checked the actuators and what I believe is the mode actuator driver side was the only one not moving. I was able to remove it and manually twist the gear to move I assume the door. Since new actuator had not come I thought moving the door would allow heat, but no. While twisting gear the whole piece turned as well. Looked at diagram but it just shows the actuator not what it connects to. Manually adjusting moves air to different vents. So is this the actuator that allows heat from core to enter? I plugged in new actuator to make sure power was getting to it and there was. Tried so hard to get it installed and couldn't before work. So I thought manually move the door with actuator connected drive to work with heat setting on to see if I got heat, nope. Manually moved door other way and tried again but this time the actuator gear doesn't move now. This where I'm stuck on what now. Thanks I know this thread is old and the info is great but I need a lil guidance I guess. Thanks
The door you moved that sent the air to different levels must be the mode selection. I believe that the temperature door will be close to the heater core itself, not on the other side of the hump.
Ok sorry for the delay, was busy. On my 05 there were two actuators. One a mode actuator, which is on the drivers sides, and the other, on the passenger side next to the glove department. Watch out in that the actuators look the same but they are not. On the Rock Auto site it’s hard to differentiate them. The blend door actuator is really cheap like $20 but the mode actuator is higher like $80. I dont have pictures so bear with me since this is from memory. The mode door is just that, it separates heat, cooling and I think fresh air modes so forces air to go to their respective coils. The blend acutuator simply blends air to the various spots like the defrost, floor, vent etc.
Ok the mode actuator is above the gas pedal and is held on by two or three 5.5 mm screws. I won’t go into the removal process since it’s been documented other places. Normally this is all y ou have to do. There is a shaft the actuator connects to but you should not not to time that. However me being stupid removed the piece the actuator connects to. That is held on by 3-4 of the same type of screws. I removed that and it then show three levers that actuate various doors. You can move them by hand just to see them move. Be careful they do interfere with each other and you will see what I mean. Now look at the piece you just took off and you will see the piece has three tracks each of the door levers slip into.j. It’s kinda a round looking track. The key here is you have to make sure they are in time so they don’t interfere with each other. It’s just a fidly process. Just do some trial and error trying to slip that piece in. Once you do that, quickly put a screw in! Wallah then put the mode actuator on and connect it. Before you button things up try it out and watch the actuator move things. If it does not then you have something binding.
Also if you want to do this, before you put that piece back in that controls the doors, start the car, let it warm up, and move each door buy hand. See if the heat comes out. Well assume you have it on heat. If you can’t feel hot air then you have a coil issue.
For others that are reading this, running coolant flush or simply flushing the engine likely won’t undo a clog in the heater core. It can clean the engine, and the radiator, but unless you disconnect the hoses to the heater core and do them separately I think the heater core will remain plugged. Good luck and I hope this makes sense. The site won’t let me upload pictures
You have a different system than mine. Mine is a manual heating one so i believe i have one less actuator. Sorry. Are you getting heat anywhere? I still suspect the heater core
That was my first post. Test post.
I would like to start off by saying Thank You to all the members that have posted such great information.
I installed the Transgo 4T65E shift kit today and it seems to have cured the hard shift problem.
Found all the info I needed on this site.
Big Thanks
Having an actuator problem also.
2002 Buick LeSabre Limited 90k
Automatic climate control
Just got the car. Got it from original owner. Pretty good shape. No heat on driver side, heat on passenger side. Realized actuator is MISSING.
The one just above and to the right of gas pedal.
I purchased a BLEND LEFT MAIN CJ2 (front auto temp controls). Part #SK604111 Actuator
I plugged it in and tested it before installing and it would only open and not turn back. I bench tested actuator, works fine. 9v battery, positive to pin 5 and negative to pin 7 for CW rotation.
Positive to pin 5, negative to pins 7and 6 for CCW rotation. I reset actuator and went ahead and installed it, with heater left off hoping I could figure it out. Might be wrong on CW, CCW but would definitely go both ways when tested just not when plugged into car.
After reading Stutz427 post above now I am hoping that the problem is that I put in a blend when I should have used a mode actuator.
If that solves the problem I will be relieved. But feel a little more stupid and a lot more frustrated because something so simple seems so complicated. When looking online at part I wasn’t sure so I checked with 2 local parts stores. After experiencing problem checked back at Advance to verify that I got the right part. They said yeah, cross referenced part #. I stayed there so long the guy offered to come out to car and stick his head under the dash to help figure this out. And he did look. Stopped at a local garage that’s been in business for 80 years and they were no help at all. Aaahhhhh feels good to vent
So I’m hoping that if I swap the blend for a mode actuator that will solve problem. I guess there is one way to find out.
Anybody have any thoughts on this. Thanks
After last post been thinking about issue.
I thought that I had verified that the mode actuator WAS working. By mode I mean the actuator that changes air flow from floor to vents to defrost.
Remove glove box to access mode actuator. Correct?
So then the blend actuator is the one above and to the right of gas pedal.
I have found videos to back up my thinking.
Google “replacing vent mode actuator Buick trq”
TRQ has a bunch of videos on replacing parts on 2000-2005 Buick LeSabre.
So now I’m thinking I jumped the gun when I read Stutz427 post above. I think he has the names reversed.
If so then I’m back to original problem.
For clarity
When I look up a GM Genuine actuator on
RockAuto they say “ make sure you choose the right actuator “
MODE
Controls which vents have air flow. Floor, Panel or front, Defrost or any combo of those.
BLEND
Controls the temperature of air flowing from the vents by mixing hot and cold air from the heater core and the evaporator core.
RECIRCULATION
Controls the intake of air into the system, either bringing outside air in or using inside air in recirculation.
MZeno, no heat could be a plugged heater core. See my post titled "Heater Core Flush Effective".
I tried to replace my Air Inlet Actuator. This is the one at the very top of this post - the very first picture. As I understand it, this actuator changes the "recirculate/fresh air". I removed all the stuff that was in front of it. But I couldn't see the actuator at all. I had to do it totally by feel. It is hidden way back there, and angled away from you. I was able to unplug the wires, got a socket on the nut, but it was so tight back there I couldn't not turn the nut out. Can anyone tell me how to get that one out? If you did, do you have any suggestions?
