ken-clifton
- Sep 29, 2018
- 2018 Encore Premium
Background: For different failure modes of the multiple check valves in the PCV system on the 1.4L Turbo engine (LUV) used in the Buick Encore, Cruze, and Sonic : 2011-2016 Cruze 1.4 PCV Valve Cover/Intake Manifold Issues
I have been looking for something to protect against pressurizing the crankcase and potentially blowing out oil seals, gaskets and the rubber disc on the valve cover that frequently happens when the non-replaceable rubber flapper check valve in the plastic intake manifold fails. According to most sources folks are lucky to get 60K before that happens (research for yourself).
When the rubber flapper check valve made into the intake disappears or fails, the turbo boost in the intake can pressurize the crankcase. Of course this can cause all kinds of issues with crankshaft seals, valve cover and other gasket failures, etc.
A *normal* valve cover breather would not work because in normal operation, there is a vacuum regulated by the diaphragm on the valve cover, with vacuum either from the intake or the turbo inlet. Such a breather would cause a severe vacuum leak. But, several performance companies have started making oil caps with a breather AND A BALL CHECK VALVE.
The replacement oil cap (w/check valve & breather) basically does nothing as long as the PCV is functioning normally... When (not if) the check valve made in the plastic intake manifold fails, the check valve in the new oil cap/breather will vent that turbo-boost pressure to protect the engine seals -- similar to a blow-off valve on a pressure cooker.
The trick it seemed was to find something that would work with the 1.4L turbo engine on the Encore. Starting in model year 2017 (and later replacement valve covers for earlier years), the valve covers come with a locking collar that implements the old-style double-helix GM oil cap design -- earlier years had an oil cap with two tangs -- not the double-helix.
After some looking on eBay and other sites, there just did not seem to be anything to work, but the folks in Florida worked with me to basically take a cap for GM and enlarge one of the openings to the helix so that the billet aluminum fits the 1.4L Turbo perfectly. If interested visit: CFM Performance Billet Valve Cover Breather for 2016-2018 Buick Encore 1.4L
(I do not work for them -- but am thankful for their help)
