As someone who just replaced about 90% of their drive train pulleys with either new bearins, pulleys , or a AC Bypass pulley, I will give some gripes of my engine specifically a 1999 L67(keything being a 99, 2000+ removes a big one)
-That engine bracket. The big one blocking the belts in. THat has to be removed for a belt. So does it on a NA of the same year, but its just especially difficult on the SC since its 2 belts not just one.
-accessing some bolts on top of the supercharger, just a pain
-if i did a coupler, a coupler on this job would just have been more mess/dirt/etc to worry about(I did it all with snout on, my coupler is good)
--by extension, SC fluid is expensive and the old stuff STINKS. animal fats and 5w-30
-PCV baffle. annoying.
-vacuum system for the supercharger, the port under snout and the lines to the bypass solenoid. just more hoses and connections.
-Airbox noise baffling, i want to hear my boost, damnit
-plastic idler pulley(Maybe tensioner pulley, one of the two) was plastic and it was worn. metal would likely be worn too, but id rather have a smooth or ribbed metal pulley and bearing instead of a plastic anything pulley on a metal bearing. heat cycles, less hardness, etc. I replaced with metal pulley fortunately
So you can see.. my actual mechanical complaints are not that serious OR lenghty and i Have done some major service to my car in the last 2 years ive had it now. more complaints come from platform-wide issues that are on riviera, park avenue, and
Oldsmobile Aurora as well or just GM decisions that are fleetwide and annoying, nothing specific because of SC
