Jeff, WIX makes most of the NAPA filters... And, WIX does not currently make an oil filter for the housings with the dark brown cap (UFI). If your car had the filter with a check valve (PF2263G) then putting the Hengst filter without a check valve in can cause serious engine damage.
As far as I know, the only filter supplier other than GM right now for the UFI housing is FRAM. Their part number is: CH12246 . Plenty of manufacturers are making the filter without a check valve that fits the Hengst housing.
I have seen several posts where folks checked behind some dealerships after oil changes and their UFI housings had the wrong filter (without check valve) installed. Again if you are worried, I would print the GM Tech Note above and take it with you...
