JGBuick
- Jun 8, 2020
- 2001 LeSabre Touring Edition
Good question. ?? Do you have access to any records? There's also other gaskets that "could" have been used that were "upgraded" to include better materials. These were supposedly meant to deal with the DexCool issues. If your lower gaskets were repaired/replaced, then I'd venture to say they used a better gasket. I'm not 100% sure on if you can see any of the gasket protruding..??How do I know if I have the metal upper intake gasket? It had the lower done at 34k and the manifold itself at the same time in 2002 so maybe they did it with the new gasket. But it still has the plastic coolant elbows. Also where did it leak when you replaced the plastic uim gasket? Or how did you know to replace it? Will the new dexcool also eat the gasket if I find out I have the plastic one?
Here's a thread from when I did mine awhile ago - Upper intake is leaking on 2002 Buick lesabre
You still have the plastic elbows?? Well... it's just a matter of time. You can watch them or replace them. But sooner or later....
Will the new DexCool 'eat" the current gaskets on your car? Don't know. Some say it's all about "Air in the system" and the condition of the system. Some say it's never been an issue.
Soooo.... lot's of conjecture and guessing here. The main thing is to be aware of the potential problems. Do a search on this site and you'll find lots and lots of posts.
