Lesabre1
- Oct 22, 2017
- Buick
These aluminum coolant elbows that we have all used to replace the original plastic ones on these 3800 motors. Ok... the problem is the O-rings break down, melt or something and then leak after 1.5 -2 years. I have had the is happen 2 other times. I have 3 cars with 3800's in them, 2 Lesabres and one Park Avenue, and all are leaking due to the O-rings failing on these aluminum elbows. Every 1.5 years or so is crazy to replace them just because the O-ring fails.
I called the company that makes of these aluminum elbows and the guy sounded surprised by this, almost like it was totally new. Searching the web today I read several times of many others having the same problem. This is not a new problem! So I ask for help here, what is the master plan to fix this so its once and done? Thank you.
