MKz2017PremII
- Aug 15, 2019
- 2017 Buick Regal Premium II AWD Turbo
Really, no one can figure this one out?
I’m having the same issue with my lacrosse or started off with the driver window not working then the radio not going off when opening the door. Now it’s saying that the driver door is open, it’s starting to get frustrating because nobody can tell me what’s wrong.I'm having the same issue on my 2013 Verion, any resolution to this issue???
My sister took hers to the dealership and was told it was the window regulator assembly, how is thisThat's weird! I would just take it to the dealer asap.
Any luck with your fix? I’m having the same issues with my 2011 Regal.Thanks 2007LucerneCXL. I found these on two other sites. It matches up with what you have said. I haven’t try the repair yet. I will repost when I do.
1. After doing some research it turned out to be the driver side window motor. For some reason they have signals going thru it. I suppose it could be loose wiring to the motor too.... but in my case it was the motor.
2. Hello again Pushrod, I want to let u know that u were spot on. After spending $217.50 they said the same thing u said. "found open wire(cut) appoximately 12" from Motor/Module in l/s drivers dr. I did get a 1 hour of diagnosis free of charge, they repaired it and rerouted the harness.
Same exact thing going on with my Buick Lacrosse 2014. Does anyone know the issues we are having?I’m having the same issue with my lacrosse or started off with the driver window not working then the radio not going off when opening the door. Now it’s saying that the driver door is open, it’s starting to get frustrating because nobody can tell me what’s wrong.
