Fault Code P2261
Greetings Jessica,
I posted a picture of the damage here to solicit opinions on what could have caused it.
http://buickforums.com/forums/showthread.php?p=167602#post167602
It was not there when I took the car in but I don't think I will be able to prove that it wasn't.
Hi again!
I took a look at the picture. 🙁 I do want to research further for you. If you could provide me with your name, address, phone number, VIN, vehicle mileage, and name of dealership via private message, I can speak with the dealership regarding the issue.
Jessica
Buick Customer Care
Do you have an aftermarket BOV? I'm pretty sure that's the same code I had. I had a forged motorsports non atmospheric bypass valve and the o ring broke. Got a thicker one in there, cleared the code and it never came back. I'd check the bypass valve, especially the I ring.
What’s BOV? Sorry 😐. I’m having same code after I replaced the whole turbo assembly for bad waste gate. It is an aftermarket turbo but everything looked like the OEM I took out. Any advice? Only kicks light on after a long drive, shut of for a bit then drive a short distance and kicks on light!!! Please help
Wow... 7 years might be a new record.
