but thats the thing. We have not determined your speed sensor harness is faulty, whats up?
On your question, on my park avenue, the WEATHER PACK connections for the speed sensors are mounted to the driver side frame rail which is under the airbox, coolant jug on a park avenue.
View attachment 38141View attachment 38142
Obviously I dont have a lesabre, and the ABS unit will be different and slightly different placement on a 2000+ park avenue/lesabre, but I suspect the speed sensor plugs are probably nearby on your car based on the diagram. I assume they still use Weather packs on a lesabre based on the diagram, but I digress. Here is mine visible.
They should all have a inter-locking plastic spear thing that physically doesnt allow them to separate until its pulled out. Similar to a seat connector iirc, similar to headlight harness if its anything like park avenue(same connector type, weather pack)
I JUST looked, it seems GM says this is for front speed sensor repairs
25737352
It seems to be the high tensioner type, and its affordable. you must splice it beyond the places of high tension of course. it has a new weather pack body, but i would suggest getting the right crimp tool for this because you dont want to play around with terminals that are gonna cause issues
View attachment 38144View attachment 38145
So after some service data diving, It seems the speed sensors ARE NOT a separate harness on lesabre up front. but part of the engine harness. According to what Im reading. this here is an example of hwere you would create a connector and plug in the passenger side harness(I realize thats a supercharger.. not sure why they used that on the lesabre data)
Front Wheel Speed Sensor Wiring Harness Replacement (Right)
Listen
Removal Procedure
| NOTE |
Important
The wheel speed sensor wiring is included in the engine harness. The wiring between the wheel speed sensor and the heat shrink sealed splices is high-flex cable and must not be repaired or spliced. This procedure replaces the high-flex cable with a jumper harness from a supplied repair kit. |
Turn OFF the ignition.
- Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
- Remove the right front wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
- Remove the wheel speed sensor connector (7) from the wheel speed sensor (6).
- Remove the harness grommet (3) from the strut bracket (5).
- Remove the harness grommet (1) from the rail bracket (2).
- Remove the harness clip (4) from the rail bracket (2).
Cut the engine harness conduit (1) to locate the 2 heat shrink sealed splices.
Installation Procedure
Replace the wheel speed sensor jumper harness. Refer to Wiring Repairs in Wiring Repair.
Install the wheel speed sensor connector (7) to the wheel speed sensor (6).
- Install the harness grommet (3) to the strut bracket (5).
- Install the harness grommet (1) to the rail bracket (2).
- Install the harness clip (4) to the rail bracket (2).
