Hi. I'm a little late with my reply, but here it goes.
2002 Lesabre Custom/limited drivers manual Pages 2-13 2-14:
Security Feedback
Mode 1: No feedback when locking or unlocking vehicle
Mode 2: park lamps, back-up lamps and DRL exterior lamps will flash trice when unlocking the vehicle and flash once when locking the vehicle.
Mode 3: Horn chirps when all doors are unlocked (second time the button is pressed) and when locking the vehicle.
Mode 4: Parking lamps, back-up lamps and DRL exterior lamps will flash twice each time the button with the unlock symbol is pressed: the horn chirps when all doors are unlocked. Parking lamps and DRL exterior lamps flash once and the horn chirps when locking the vehicle.
If your vehicle is not equipped with the DIC, do the following to change to another mode:
1. Close all the doors and turn the ignition on.
2. Press and hold LOCK on the driver's power door lock switch throughout this procedure. All the doors will lock
3. Press the trunk button on the transmitter.
The security feedback will remain in its current mode. The horn will chirp as feedback.
4. press the trunk button again. Each time the trunk button is pressed, the security feedback will advance to the next mode, and the horn will chirp.
5. Release the power door lock switch. The security feedback will remain in the most current mode selected.
(page 2-14)
This procedure only changes the mode for the transmitter used to change this setting. The procedure will need to be repeated for the second transmitter.
To verify the mode selected, remove the key from the ignition and close all of the doors after you've exited the vehicle and confirm the appropriate feedback. Repeat with the unlock button.
Hope this helps. it worked on my 2002 Lesabre custom (without DIC)
