Dubv1980
- Apr 8, 2016
- Northern Virginia
- 2016 Verano Turbo
So here's the first real "problem" I have had with my Verano. This started last winter, and as the weather has turned chilly again, it has emerged again.
I'm having a problem with the Verano recognizing that the key fob is in the car. Initially, I assumed it was a battery issue, but the dealer said they never see the batteries go bad after less than a year, and the fact that it was doing it with BOTH my key fobs equally, seemed to exclude the battery as the problem.
I took the car in last week and they did a software update, and while it was at the dealer, it had no problems. But lo and behold, went out to the garage yesterday morning and...the car won't recognize the fob. As we all know it prompts you to place the fob in the transmitter pocket...but even then it usually takes a good minute or so for it to recognize it and let the car start. This never seems to be an issue when I leave work in the afternoon, when the car has been sitting out in the parking lot (even if its freezing), it only seems to be an issue in the morning, in cooler or cold weather, even though the car lives in the garage (albeit unheated) and the key fob obviously has been sitting in the warm house.
The Verano is under warranty, so I'll get the problem taken care of eventually I'm sure, but I'm just curious if anyone else has had this issue, and if so (outside of the batteries) what ended up solving it? It might be helpful so I can point the service guys at the dealership in the right direction as they thought a software update would do the trick.
Chris
Chris
