I'm also having trouble programming my 1991 Roadmaster wagon. The car has 50,000 original miles and I found the key fob in the glove box, unopened, and still in it's original packaging (perfect condition inside and out). I replaced the batteries because I figured the ones from 1991 were long since dead. I found the lead wire on the RIGHT side compartment where the spare tire is (1991 only), above the taillight (I checked the left side first and found nothing in the D pillar or behind the lockable storage compartment). It is a single wire connector. I connected alligator clips to the connector pin and grounded it to a piece of metal on the side of the car. It went through the lock cycle as it should, but nothing happened with the remote when I pushed a button. I tried several times, pushing different buttons, but nothing. I tried disconnecting the battery of the car for 30 seconds and starting over, but nothing.
I did get the lock and unlock buttons to work (not the rear window button) on the fob only when I had the key turned to the 'on' position, but it stopped working immediately after turning the key off (it also never confirmed the programming by going through the lock cycle after pushing a button, the lock & unlock just started working shortly after pressing the button... with the key in the on position). Seems like the TRW system is clearing correctly. The key fob can work at times, but why can I not get it to program correctly? Please help!
Here's what I did:
- clipped the pin on the wire
- clipped other end to ground (lock cycle performed by car)
- pressed a button
- No lock cycle response from key fob
- unclipped wire
- not programmed
