InfiniteImp
- May 22, 2010
- Toronto, ON
- 2010 LaCrosse CXS, 2015 Infiniti Q50 AWD Sport Hybrid
For your information, Road force balancing is a scam period. All and i mean ALL vibration is caused by tire/wheel assembly. Usually 99% of the time TIRES. If the tires are properly balanced and NOT DEFECTIVE. the car's front end can be loose as a goose, out of alignment, etc., and you will not get vibration/shimmy/shaking, etc on a relatively smooth road. As I have mention in numerous articles and borne out of extensive experience, Several factors cause vibration from tires. Simple out of balance; tire run out both circumference and lateral; non-linear circumference tread/sidewall stiffness;
I'll defer to your experience on this one as I have none. I know the posts I read about it seemed to make sense and the road force balancing process itself appeared to have a good logical basis to it. In my case, the road force balancing did nothing to address the problem, backing up your assertion. Thankfully they charged me the cost of a standard balance given that the road force balance didn't help. In any case, it's not over yet. If I can somehow get a replacement tire in warranty or even pro-rated, that would be a good next step for me.
