The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
How old are the tires?2013 Lacrosse has the loudest road noise I have experienced. Not tires or wheel bearings or anything malfunctioning. Is there a way to dampen the noise?
I have owned the car for 2 years. Tires were new then. They have about 20,000 miles now. The noise is the same, seems louder now but I suspect I am just more focused on it now. Shop has checked car for issues and pronounced it without issue. Tire pressures have been adjusted from 33# to 36# and driven many miles at both levels. Road noise or suspension noise or whatever is continuous regardless of tire pressures. It increases with road speed.How old are the tires?
Do you have tire pressure set to the cold numbers listed on door pillar?
Without actually hearing it hard to advise other than have a shop check the car.
Has someone from the shop driven the vehicle with you.I have owned the car for 2 years. Tires were new then. They have about 20,000 miles now. The noise is the same, seems louder now but I suspect I am just more focused on it now. Shop has checked car for issues and pronounced it without issue. Tire pressures have been adjusted from 33# to 36# and driven many miles at both levels. Road noise or suspension noise or whatever is continuous regardless of tire pressures. It increases with road speed.
No. Admittedly I am confident in my diagnosis. This is not a transmission problem, or a bearing issue, or tire noise. I was hoping to get confirmation from others that this is a common issue that many other people experienced with their 2013 Lacrosse model car.
