G
G-444132
They are quite easy to remove just by hand. Simply unplug the connector and then wiggle it loose and it will slide out. My understanding is a new one also needs to be reprogrammed. When I scanned mine the codes I got were lost connection with Right hand side and Right hand side error. Switched the left and right, cleared the codes and the error came back on the left. I just did this to confirm which module it was. By the way the one module was clearly swollen. Visual inspection will tell you pretty quickly if its bad. I am going to try getting one at a wrecker and see if I can get it to workThank You so much. is it possible to get to modules without removing he bumper cover?
If I were to get a new module does it have to be programmed by the dealer as well?
Thanks Again
