G
G-804999
Years ago, I learned to increase the recommended pressure by 4 PSI when mounting snow tires. Is this still a thing? No mention of it in the owners manual. 235/50-18 97H Cooper snow tires. Any opinions?
The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
No - Go by what your vehicle's door jamb sticker says NOT based on what the sidewall says.85-90% of the maximum pressure listed on the sidewall. Tires today need more pressure in some cases. Years ago, tires had maximum inflation pressures of 32 psi, then it was 35, today, 44 and even 51 psi tires are common. Look at the sidewall first.
On a fairly new car, yes. The door sticker is based on the tires that came with the car at that time. Like I said, tires have changed in the last 5-8 years. If tires that have a different maximum inflation pressure are used, the door sticker can be inaccurate. Example, my 98 Riviera door sticker says 30 psi all around. The car came with tires that had a maximum inflation pressure of 35 psi, very common at the time. About 8 years ago, I put Yokohama Avid TRX tires on it. Max inflation, 51 psi. 30 psi in them, and the car wallowed all over the place. Steering response and turn in were pathetic. I also noticed a reduction in gas mileage. Put 43 psi in them and the difference was amazing. You might think the ride was hard, but it was great.No - Go by what your vehicle's door jamb sticker says NOT based on what the sidewall says.
Thanks for the link, and verifying that it wasn't all in my imagination.
You may want more sidewall on those for winter. 🤣I've noticed that adjustments for seasonal changes seems to make improvements in ride and handling IMO.
18 TourXDear OP,
What vehicle are you asking about?
Thanks, I haven’t been called that in a while. Merry Christmas!Studs
If it is the same size as the stock tires, then it should be the same at 32 psi cold at the minimum.18 TourX
