glavey
- Aug 6, 2021
- 2003 Buick Lesabre Limited
Nearly every write-up and how-to involving the bolts that secure the lower intake manifold to the heads say to use a thread locker, typically blue loctite, on the bolts. According to Permatex's technical data sheet on their blue threadlocker, it withstands temperatures up to 300F. That seems a little close to the operating temperatures of an engine.
Will blue loctite hold those bolts good enough or should I use something else? I found some loctite 246 on amazon, but I have a hard time believing that with the increased temperature resistance, the bolts will still be able to be removed with hand tools if the need arises.
