Rumdada, the following information is from your owner’s manual:
Recommended Fuel
If the vehicle has a 2.4L L4 engine
VIN Code C), use regular unleaded
gasoline with a posted octane rating
of 87 or higher. If the octane rating
is less than 87, an audible knocking
noise, commonly referred to as
spark knock, might be heard when
driving. If this occurs, use a
gasoline rated at 87 octane or
higher as soon as possible. If heavy
knocking is heard when using
higher, the engine needs service.
If the vehicle has the 3.6L V6 engine
VIN Code D), use premium
unleaded gasoline with a posted
octane rating of 91 or higher. You
can also use regular unleaded
higher, but the vehicle's acceleration
could be slightly reduced, and a
slight audible knocking noise,
commonly referred to as spark
knock, might be heard. If the octane
is less than 87, a heavy knocking
noise might be heard when driving.
If this occurs, use a gasoline rated
at 87 octane or higher as soon as
possible. Otherwise, you could
damage the engine. If heavy
Thanks,
Laura
Buick Customer Service
