ede smith
- Apr 8, 2021
- Century
“They are ‘Bubble’ or ‘ISO’ flares, not a double flare… Despite what the internet tells you, you need a bubble flare tool.” Buick Forums
“My Reatta… uses a flare called an ISO flare. … Do not let the counter People tell You that all that is, is a double flare. It is not and They can NOT be interchanged.” AACA Forums
“Older brake lines require a double flare… But newer GMs (mid‑90s and up) use a bubble flare which is a different flaring tool.”
I was going to do that, but was trying to figure out the correct flare—and then ulcyc's recommendation changed my course. Have you replaced yours with NiCopp and if so which flaring tool did you buy? The Lisle flaring tool I was looking at was $70, the NiCopp roll with some fittings was.$30. A decent 3/16" tubing bender like the Rigid one is $70, although it sounds like that wouldn't be necessary. At $100 that's about 1/2 to 1/3 the price of preformed lines which certainly is a savings, although time should be a factor too as I will be doing this on my back on the concrete driveway.My recommendation is to purchase a 25 foot roll of NiCopp in each tubing size you will need along with the required brake nuts/fittings, and then get one of the loaner brake flare tool kits from Advance/Carquest, O'Reilly or AutoZone, and make your own lines.
NiCopp is much, much easier to work with compared to steel or stainless steel lines, and will last far longer than any steel or stainless steel brake line. Making flares on NiCopp is also much easier! NiCopp is stronger than steel or stainless steel, is DOT approved for brake lines and does not need special tools for making curves or bends in it.
You can order NiCopp online from rockauto.com or amazon for extremely reasonable prices as compared to getting it locally at a brick and mortar parts store.
Yeah I will be working on my back in the driveway. What are your preferred tools for this? I think I left my brake bleeder wrench and am trying to make sure I have everything on hand before beginning!I've done many cars with rolls of brake line and the proper tools on a lift. But for a novice working in his driveway ready fit lines is the way to go. Also will cut the time laying on your back in half. Also getting the correct fittings and unions can be a headache and waiting for the post office to show up.
