RegalTurbo
- Dec 15, 2010
- Canada
- BuickRegalTurbo
Hello everyone!
Owner of a German Built 2011 Regal Turbo with all options but Nav. (not sure what package that is.) I'm having a number of issues with my vehicle and have had it in the dealer a number of times.
First issue I am having has to do with the engine making a weird noise on startup. If the vehicle has been sitting for a couple hours and I start it the RPM's go up to about 1500 rpm's and then after about 30 seconds fall to under 1000. I think this is normal on startup when the vehicle has been sitting for awhile, however, it makes a really weird noise when you put the car in reverse or drive. Let's say I put the car in reverse to back out of a parking spot, after I remove my foot from the brake and let the vehicle coast out of the spot (not putting foot on accelarator pedal) it will make a very odd noise for about 30 seconds. I've had it in the dealer a number of times for this however they have not been able to find what is causing the noise becuase it only lasts about 30 seconds and then goes away. Also, if I just flutter the gas pedal when I first put the car in drive you can hear the noise as well. I'm not really sure how to explain the sound it makes. It's a very grinding like noise..
Second issue I am having are the brakes, more specifically warped rotors. Anyone else having an issue with this? Basically, any high speed braking and the steering wheel magically becomes a shake weight. also noticeable at low speed braking too.
Third issue is looseness in the steering. Anytime I drive on an un-even road or brake on an un-even surface the steering wheel wants to wander all over the place. I basically have to fight the steering wheel to keep the car going straight. This is very annoying because I constantly need to corrective steer the car. Is this caused by the size of the tires? Or could it have something to do with the suspension system in the front end? I've had it in the dealer for this as well and they tell me it's fine but I don't think it is suppose to be that loose.
All in all at this point I am a little discouraged over the problems I am having with my vehicle and I don't know what to do.
Anybody else been having these problems?
