How would an aftermarket system alleviate the door resonating on certain pitches? An aftermarket speaker would create the same pitch which would then in turn create the same resonance. Sounds like you may need some dynomat to keep the door panel inert. If what you are hearing is actually distortion then the amp is clipping. A more powerful aftermarket amp would solve that problem.
I agree, if the door is resonating the only good fix is to pull the door panels off, add sound deading to the back of the trim panel, and add it to the back of the sheet metal on the door.
Reverb or resonance is a common problem on door speakers, even my friends AMG with a HK sound system does the same thing with certain songs and pitches. It's the natural resonance frequency of the materials and when they match with the music, vibration is bad and it might resonate terribly. Natural resonance frequencies are usually very low in the tone scales, if your getting resonance it's a good and a bad thing... At least you know the frequency range of the speakers (assuming they are not bottoming out) is going as low as you media is asking it to.
Although it could also be speakers bottoming out or the amp clipping.
A dealer tech would be the last person who's opinion I'd listen to on sound quality issues
😀 (unless he also happens to be an enthusiast).
I'm content with the sound system in mine, not perfect but I didn't expect one either, I have noticed I need to turn bass down in the HU considerably to avoid 'boomy-ness'.
I guess its a case of expectations. I haven't noticed any bad resonance on mine, and I have usually had a car or two with "OK" built up ($2000-3000) sound systems in them. The regal's stock stuff can't touch a good aftermarket setup, but as far as resonance and odd sounds go, I haven't noticed any, and while I'm no pro, I do like my music a bit louder and clearer than most.
I also wouldn't be surprised if there was a foreign object bouncing around inside the door... Someone forgot their safety glasses or something in there
