Re: OE fuel system concerns and ZFR turbo installed pics
Built block before tranny= not going to be good.
Front wheel drive and shooting for 400 with no limited slip in tranny= going no where fast.
who says i don't have some OS giken going into the car right after i have raybestos clutch packs installed after backcutting the carrier and shoving in a full two more friction plates in there? (auto trans)
some bridges are going to have to be crossed when we get to them, but thats another thread and PM material, as the purpose of this thread was meant to tell everyone that yes, a ZFR fits and has tuning support, RIGHT NOW
http://i45.tinypic.com/amfx1j.jpg
some
mods and clearancing is necessary:
on the blue part the heat shielding needs to be cut,
on the green part this air line is just completely different than what came on the stock/OE turbo
and on the orange part, the oil line needs to be modified (lengthened)
the other orange part shows the minimum clearance between the turbo and an AC line, which is about a half inch or so away from the side of the turbo?
Also looks like your rocking a flex plate, so it's an auto car?
yes, its an automatic
Seems like the DI injector size is going to always be a limiting factor.
the OE (E85) fuel system in the LHU/LDK/etc engines are going to have more capacity if only marginally more than the LNF, of which there are plenty of examples running at ~400whp without either a fifth injector or a ZZP camshaft fuel pump lobe upgrade, so yes, it'll probably be a limiting factor eventually, but not more so than either the auto trans or FWD in this case
What are you doing for fuel?
As said what's the fuel increase you plan on doing since im sure you're maxed out now?
if the OE (E85) fuel system fails, then the ZZP camshafts with the larger fuel pump lobes are going in (sitting on a shelf waiting - would like to avoid installing them as it'll affect emissions and idle quality though), and if that fails, then a 5th injector setup is next, and if that altogether fails, then i'm going to machine the cylinder head and weld on a flange and expand the bore of the DI fuel pump to accept a DI pump and lifter out of an LFX engine and if that fails i'll remachine the heads and stick two of them on there, at opposing directions (one will sit off of where the valve cover currently is) and then machine billet stock and gun drill for the DI fuel lines
and if that fails i'll wire in a piggyback fuel solution based off of RPM (window switch most likely) and if that fails i'll swap to standalone with a full set of external port injectors and if that fails then i'll torch the car and claim the insurance money and then buy a V8, pretend none of this stuff ever happened and then get years of therapy to make the nightmares stop
Since when did GM offer a sleeveless ecotec block?
the block still has sleeves, but just really thin sleeves:
http://i47.tinypic.com/15n2brm.jpg
i don't think i've yet come across someone basing their shortblock build on an LHU/LDK block yet (no comparison material available), so that may be part of how the block is different?
the block pictured is the one out of the car
do you have any more details about your Trifecta tune?
i'll send you a PM or we can go into further detail in another thread - but yes, i have a dyno graph of stock vs tuned
