mjspiess
- Jul 23, 2013
- Buick
I discovered my wife's 2013 Buick Encore with 25k miles was leaking oil a few weeks ago. I meant to check it out sooner, but finally crawled under to investigate. I'm glad I did because the engine was down an entire quart of oil! I discovered there were 3 distinct drip points, but no distinct trail leading to those 3 points. The 3 points of dripping were the oil drain plug, I assume the low oil sensor port and the spring tensioner...I think for the alternator...I can't recall now. There was oil all over the oil pan, mostly on the right side of the engine and as high the spring tensioner and just below the turbo intake port. I didn't see any signs of oil at the turbo oil inlet or valve cover...2 areas normally found in the Cruze scene.
I took it in because I could not determine where the leak was actually coming from and neither could the dealership. They think it's possibly coming from the valve cover gasket. I think it's coming from the the oil pain "gasket". They cleaned it all up and added a dye to the oil and will black light the area when they install the seat belt pretensioners in a couple weeks for the recall. I will update this thread when I get an answer.
